10-09-2002 11:22 AM - edited 07-04-2021 11:26 PM
Got two airo 350's back to back in adhoc mode everything worked just fine. Worked yes, untill recently all of a sudden I get the following message in the syslog.
airo : BAP setup error too many retries.
Nothing, that I can think of, has changed. Running the followin versions on my systems :
Both the AIROv15000 package.
One system is running RH 7.2, this one gives the error.
The other one is running RH 7.1.
ACU and the LEDS say the interfaces can see each other. Signal level is ok but there is nothing going on at layer 3.
Any clues ?
Solved! Go to Solution.
10-16-2002 08:43 AM
You may want to try the latest drivers and firmware off of the Cisco Software Center to see if that fixes you issue.
10-16-2002 08:43 AM
11-04-2002 08:40 AM
Updated to the latest firmware release on the pci interface. Had to do that before I could upgrade to the latest software release. But after th firmware upgrade everything seems to be up and running again.
Don't now how, but it works for me.
Cheers,
Bart Bokhorst.
