BBSM and Wireless Lan Controller
These might be a simple question,
1. Does BBSM 5.3 supports WLC 2006 or any Wireless LAN Controllers? Where can I find a documents on how to configure both device?
2. Does BBSM 5.3 supports Cisco Catalyst Express 500? What should the switch type am I going to use?
Thank you
1. have a look at http://www.cisco.com/en/US/partner/products/ps6366/prod_technical_reference09186a0080706f5f.html for WLC based Guest access solutions.
2. find a list of supported devices at
http://www.cisco.com/univercd/cc/td/doc/product/aggr/bbsm/devices.pdf
Regards, Michael
Hi Michael
Thanks for the reply.
Seems that item #1 requires authentication to access the resource given... Not of much help...
