Binding interfaces on WLC 5508
Mark Jensen
               Hello, I would like information on binding multiple intefaces from the WLC to a Cisco switch for more bandwidth. Can someone point me in the right direction for this? thank you
One more doc:
https://supportforums.cisco.com/docs/DOC-23515
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
Here are some links.  You need to have LAG enabled on the WLC and then you need to create an etherchannel to your switch.  You can connect the WLC to multiple switches if they are in VSS.
https://supportforums.cisco.com/docs/DOC-20587
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_ports_interfaces.html
Scott
-Scott
One more doc:
Scott
-Scott
Thanks these should do it for me.
No problem... thanks for rating!
Scott
-Scott
