Community Member
Bouton MODE not Enable
Please i need a help, I try to recovery the password of One AP Aironet 1200 series (AIR-AP1231G-E-K9) but the bouton mode is not Enable, so can you help me ,
Note: i already try to press esc when the flash is loading but i no think is happen
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
button pressed for 15 seconds
process_config_image_recovery Failure
Mode-Button not enabled
Loading "flash:/c1200-k9w7-mx.123-8.JA2/c1200-k9w7-mx.123-8.JA2"...############################################################################
Everyone's tags (3)
Hi, Please do go through the
Please do go through the attached file to reset the AP to factory defaults.
However, make sure you have not pressed the mode button for long as that will delete the image completely and will get the AP to ROMMON mode.
Let me know if the AP is already in ROMMON mode, or if you have any other queries regarding this issue.
Salma
Community Member
I see this message when i try the first option and for the second it's not possible because i have not the the password.
158
