Br1300 Point2Point-link carrying multiple Vlans?
I want to configure 2 1300 Bridges as a point2point-link between two buildings. I want the radio link to carry 3-4 different vlans.
Each bridges ethernet-interface will of course be configured as a .1q-trunk and will be connected to a switch which interface is also configured as .1q.
BUT. How do I configure the radio link to be q-tagged? Is it possible to transfer more than one vlan in the same SSID? Or do I have to create one SSID per vlan I want to carry?
Thanks in advance
Jimmy
1 REPLY
kka
Re: Br1300 Point2Point-link carrying multiple Vlans?
For bridging of dot1q-trunks only a single SSID is used. The VLANs
are created as subinterfaces on the Ethernet- and Radio-Interfaces.
With the GUI use SERVICES->VLAN to create the VLANs.
This will create the subinterfaces and bridge groups on both Ethernet-
and Radio-IF. (If you don't mark any VLAN as native, VLAN 1 is native)
To configure VLANs using the CLI, you might want to take a look at
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a00804ed724.html
IIRC correctly the management IP of the bridge is always in the native VLAN.
152
