02-26-2014 08:47 AM - edited 07-05-2021 12:17 AM
I´m planning right now a local Guest Access breakout for a Branch Site which is connected over
a HREAP AP to a centraliced WLC . If I have it correctly understand then I´ve to do following:
1. Creat a Guest SSID on the centralized WLC ( 5508 ) / enable local switching for this SSID
2. Create a Guest VLAN on the Branch Site with a local Internet breakout
3. Configure a Trunk port for the HREAP AP on the Branch site ( 1 VLAN for Corportate SSID/ local switching and 1x VLAN for Guest
with local Internet breakout )
Can I use the WLC as DHCP server for the Guest SSID or should I use a local DHCP server ? I know about a feature
"central DHCP Processing " but I never used this before and it is not 100% clear if this can help me in this case.
Thanks for help.
Solved! Go to Solution.
02-26-2014 02:06 PM
Local switching really requires you to have local DHCP. Now this is to support when the FlexConnect ap is in standalone. You can use a centralized DHCP server but wouldn't use the WLC as it's not supported by TAC.
02-26-2014 09:02 AM
02-26-2014 02:06 PM
