01-09-2014 10:26 AM - edited 07-04-2021 11:55 PM
Is there a way to make AP mode change to flexconnect / flexconnect vlan mappings to a group of AP's at the same time?
01-09-2014 10:50 AM
Hi Dan,
I do not think so. (not sure any prime template can be used for this though)
Anyway you have to change AP mode to Flexconnect individually, do the VLAN mapping as additional step in that task.
Rasika
**** Pls rate all useful responses ****
01-09-2014 02:35 PM
There might be a template you could push from PI that will set the vlans on the AP if it's already in FlexConnect mode.
I usually just do those changes from the cli myself though.
Steve
01-09-2014 03:10 PM
in 7.5 and 7.6 have a feature where you can push vlans to flexconnect group where the flex APs were added.
01-10-2014 03:33 AM
Just to add... You can create a cli command script to change the mode if the access point from local to FlexConnect and then change the native vlan then add the WLAN to vlan mapping. I put something out on the forums a while back to change the WLAN to vlan mapping which might help.
https://supportforums.cisco.com/thread/2221117
