Community Member
C1811W routed VLANS
C1811W. Working through Wireless Application template to set up a "hotspot" guest WLAN - with SSID "hotspot" in beacon - and the employee WLAN bound to the wired LAN - SSID MT8160 - not being broadcast per template.
I have no problem connecting and getting out on the guest WLAN - but the employee WLAN SSID will not show up in the list of available wireless connections after I manually add it in.
Here is the router config. Can anyone help troubleshoot? Thanks.
dot11 ssid MT8160
vlan 2
authentication open
dot11 ssid hotspot
vlan 100
authentication open
guest-mode
ip dhcp excluded-address 192.168.16.1 192.168.16.9
ip dhcp excluded-address 192.168.17.1 192.168.17.9
ip dhcp excluded-address 10.10.100.1 10.10.100.9
ip dhcp pool sdm-pool1
network 192.168.16.0 255.255.255.0
dns-server 172.16.0.10 172.16.0.8
default-router 192.168.16.1
lease 0 2
ip dhcp pool employeeW
import all
network 192.168.17.0 255.255.255.0
lease infinite
ip dhcp pool hotspot
import all
network 10.10.100.0 255.255.255.0
default-router 70.62.60.205
lease infinite
interface Dot11Radio0
no ip address
no dot11 extension aironet
ssid MT8160
ssid hotspot
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
ip address 192.168.17.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no cdp enable
interface Dot11Radio0.100
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
ip nat inside
no cdp enable
interface Dot11Radio1
no ip address
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
(This wouldn't take the entire config. If you can help, I can upload other items not listed if needed. Thanks.)
1 REPLY
Bronze
Re: C1811W routed VLANS
good morning
what stands out is you donot have a seprate bridge-groups setup for VLAN 2 and 100
the employee ssid is not broadcast because guest-mode is set as it is on the guest VLAN.
Guest-mode is the option that determins if the SSID is broadcast or not the check box on some GUI interfaces say Broadcast SSID but in the config the command is Guest-mode, this broacasts the SSID in the Beacon and makes th WLAN eaiser to find ie you do not need to know the SSID to configure the wireless interface in hte client.
it is my understanding that only broadcast SSID's will show up in the list of available wireless connections.
Managing in house wireless through group policy works very well and is able to set the prefered Wireless network for the end user.
Bill
192
