01-03-2014 05:40 AM - edited 07-04-2021 11:53 PM
I have a centrally located wlc and access points spread over several "remote" locations.
Is it in anyway possible to have an AP act like a credentials cache, at least for little while for existing wireless connections, until the wlc is back??
In this case the authentication is 802.1X with certificates.
I seem to remember something about this beeing possible in som degree but i fail to find it in written text.
Hopefully someone can shead some light on this.
Solved! Go to Solution.
01-03-2014 06:11 AM
FlexConnect, with a Flex Group, can do this to some extent. It doesn't cache the credentials, but it does allow you to define a 'backup' radius server that the AP can authenticate with durin the timeframe that it can't reach the WLC>
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_flexconnect.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
01-03-2014 06:11 AM
HTH,
Steve
01-03-2014 06:46 AM
Thanks for the quick response that was exactly the info i was looking for.
Now to see if the theory meets with reality.
Thank you again.
