Can a 1811w be configured as a HotSpot?
Gerard Roy
Level 2
Level 2
Can an 1811w be configured as a Hotspot? I want a guest VWAP and a private office VWAP (Multiple ssids) and how would authentication be done? A local database on the router or does the router support access to an LDAP database (Microsoft)? Is a NAC device required?
mat.edwards
Yes you can configure the router for a hotspot, choosing to broadcast multiple SSID's. Each SSID can be configured with different authentication methods including backoff to external RADIUS/DB if required. NAC isn't required to do this.
Config guide for most of your requirements below:
http://www.cisco.com/en/US/partner/docs/routers/access/1800/wireless/configuration/guide/awg.html
Hope this helps.
Mat
