Community Member
Can I use two antennas on one bridge?
Can I connect two patch antennas on one bridge?
One is for the left and another is for the right of bridge which is inbetween.
Can I do that ?
Community Member
Re: Can I use two antennas on one bridge?
The idea of antenna diversity is to solve problems with multipath interference.
Bridges are meant for point-to-point links, and as such only have one antenna connector. If you want to add a "repeater" style function between two bridges, the best method is to use two bridges in the middle, connected by Ethernet.
EG: [Left Bridge] Radio [Middle Bridge 2] Ethernet [Middle Bridge 2] Radio [Right Bridge]
So you end up with four bridges, as two separate point-to-point links. There's plenty of documentation on CCO describing these ideas.
You can not use two antennas to cover two different area or to speak to two different bridge , Purpose of two antenna connector is for the diversity ,
It listens to one antenna a time , so while it is listening to one antenna , it is
deaf on other antenna .
You may want to have Omnidirection Antenna on the middle bridge , also
you have to configure middle ( hub side ) as root bridge .
( Omni Direction )
br 1---Direction Antenna -- ------ Hub Bridge----------Direction Antenna --br2
