11-19-2008 12:16 PM - edited 07-03-2021 04:47 PM
I am in the process of configurating a secure and unsecure wireless network. One SSID is in vlan 204 and the other in vlan 9. I have set the second one up as SSID in Guest mode and selected multiple BSSID. I can see the AP is broadcasting both SSIDs but I can't associate with the second SSID.
What did I fo wrong?
Mike Williams
11-20-2008 06:41 AM
If you can, please post your configuration so we can see what might be misconfigured.
If I had to guess based on the symptom, your security is probably misconfigured. Did you include the "authentication open" command? This is needed even on interfaces with no security.
11-20-2008 08:05 AM
11-20-2008 11:17 AM
Hmmm... I see that you attached a file, but I don't see the file :/ Want to try attaching it again, or maybe just copy/pasting it?
11-20-2008 11:35 AM
