Can't configure a replacement AP1230B
Hi Jason,
I received a replacement AP and tried to configure it.The AP doesn't come with antenna.
After the AP boots up, I can't input any command from the console mode.
( I tried to reset/power cycle the AP a few times, same result). The status LED is flashing(green).
And I kept receiving the following message:
*Mar 1 00:01:28.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:01:37.576: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:01:38.576: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:02:02.685: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:02:03.685: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:02:07.576: %LINK-3-UPDOWN: Interface BVI1, changed state to down
Is it a defective unit? or is it any way to configure it.
Thank you for your reply.
Ethan
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
Loading "flash:/c1200-k9w7-mx.123-7.JA/c1200-k9w7-mx.123-7.JA"...##################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w7-mx.123-7.JA/c1200-k9w7-mx.123-7.JA" uncompressed and installed, entry point: 0x3000
executing...
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(7)JA, RELEASE SOFTWARE (fc1)
Initializing flashfs...
flashfs[1]: 140 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4920320
flashfs[1]: Bytes available: 2821120
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-AP1230B-A-K9 (PowerPC405GP) processor (revision A0) with 14838K/1536K bytes of memory.
Processor board ID FOC075114W3
PowerPC405GP CPU at 196Mhz, revision number 0x00C4
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
Press RETURN to get started!
*Mar 1 00:00:06.552: %SYS-6-LOGGERSTART: Logger process started
*Mar 1 00:00:06.554: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:07.554: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar 1 00:00:25.641: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 1 00:00:25.723: %SYS-5-RESTART: System restarted --
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 09-Aug-05 21:10 by kehsiao
*Mar 1 00:00:25.724: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:00:26.641: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:26.673: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:37.576: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:38.576: %LINEPROTO-5-UPDOWN:
Silver
Re: Can't configure a replacement AP1230B
I take it you can log into other Cisco devices with this computer?
Check your serial settings, try a different console program, and try a different PC. If none of that works, it sounds like a bad console port.
I just reset console program configuration after i post this question, and it works.
Thanks Jeff.
202
