01-05-2012 04:26 AM - edited 07-03-2021 09:19 PM
Hi guys,
Iam having trouble to conect my 1121-AG AP`s to my 4404 WLC.
My WLC version is 7.0.116.0.
I can see he AP is getting an IP address from the controller(internal DHCP).
But from some reason they can`t connect to the WLC.
I have tried many things such as:
1)reset to default settings
2) move the AP to Autonumos mode and back to LWAPP mode -- didnt help.
Do you guys have any idea?
P.S
1 of my AP 1121AG is working properly.
01-05-2012 05:07 AM
Look at the error log on the wlc and console into the ap to see what's happening. You might need to add the SSC to the wlc before it can join.
01-08-2012 10:55 PM
Hi scott,
I can`t see any error logs in the WLC.
I can see the AP get IP address but for some reason he dont join to the WLC.
Plus- the AP 1121-AG dont have console port to connect.
Any ideas ?
01-23-2012 06:25 AM
Policy Configuration | |
Accept Self Signed Certificate (SSC) | |
Accept Manufactured Installed Certificate (MIC) | |
Accept Local Significant Certificate (LSC) | |
Authorize MIC APs against auth-list or AAA | |
Authorize LSC APs against auth-list |
Also need to make sure that you are accepting SSC's and MIC's and LSC's... this can be found under security, AAA, AP policies...
Tony
01-23-2012 07:32 AM
Hi Tony,
I checked the boxes and they still won't join.
thanks
Omer
01-23-2012 07:45 AM
On that same page, do you have any "AP Authorization List" entries? There needs to be one with the MAC of the AP and the self-signed certificate(SSC) or manufacturer installed certificate(MIC) SHA1 Key Hash
You can add your AP here(if not already) by getting its MAC address from the back of the AP.
Let me know if this works.
Tony
>>> omer_shtivi
Home ( https://supportforums.cisco.com/index.jspa )
Re: Can`t join my 1121-AG to the controller created by omer shtivi ( https://supportforums.cisco.com/people/omer_shtivi ) in Other Wireless - Mobility Subjects - View the full discussion ( https://supportforums.cisco.com/message/3541650#3541650 )
Hi Tony,
thanks
Omer
Reply to this message by going to Home ( https://supportforums.cisco.com/message/3541650#3541650 )
Start a new discussion in Other Wireless - Mobility Subjects at Home ( https://supportforums.cisco.com/choose-container!input.jspa?contentType=1&containerType=14&container=2043 )
This message is confidential, intended only
for the named recipient(s) and may contain
information that is privileged or exempt from
disclosure under applicable law. If you are
not the intended recipient(s), you are notified
that the dissemination, distribution or copying
of this message is strictly prohibited. If you
received this message in error, or are not the
named recipient(s), please notify the sender
and delete this e-mail from your computer.
ETMC has implemented secure messaging for
certain types of messages. For more information
about our secure messaging system, go to:
http://www.etmc.org/mail/
Thank you.
01-09-2012 02:13 AM
Run a debug on the ap then. But you should see that the AP joined or did not join. Did you add the AP's SSC to the wlc?
Take a look at these links
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00806a426c.shtml
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
01-10-2012 01:50 AM
hi scott,
i'm working with liad on the trouble.
i tried the debug commands in the links and the only message i get for my ap mac is:
(Cisco Controller) >*sshpmLscTask: Jan 10 11:42:32.558: sshpmLscTask: LSC Task received a message 4
*sshpmLscTask: Jan 10 11:44:32.559: sshpmLscTask: LSC Task received a message 4
but when i debug dhcp packet enabled.
i get:
*DHCP Proxy DTL Recv Task: Jan 10 11:08:02.186: 00:11:bb:80:57:9c DHCP received op BOOTREQUEST (1) (len 267,vlan 16, port 1, encap 0xec00)
*DHCP Proxy DTL Recv Task: Jan 10 11:08:02.186: 00:11:bb:80:57:9c DHCP dropping packet (no mscb) found - (giaddr 0.0.0.0, pktInfo->srcPort 68, op: 'BOOTREQUEST')
01-09-2012 07:35 AM
are you sure the 1121 has the MP31G card in it? If not, it'll have hte MP21b, and a B only AP is not allowed to join the WLC.
HTH,
Steve
01-21-2012 11:40 PM
no,
the 1121 got the AIR-21G-E-K9 in it.
does it mean i can't connect it?
01-22-2012 05:40 AM
all the -E is saying is the country code nit the radio module that is installed. Can you pull a show country from the WLC?
Steve
01-22-2012 05:43 AM
The Country code set to IL.
