Community Member
Can't Ping Wireless Clients
I am having a problem pinging any wireless clients. They associate, DHCP fine and can access hosts on the wired side. However, from the router or any wired device in the same vlan as the wireless device, I get no replies from the ping. This had worked before. Here's the AP1100 config:
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 blah blah transmit-key
encryption mode wep mandatory key-hash
encryption vlan 403 key 1 size 128bit 7 blah blah transmit-k
ey
encryption vlan 403 mode ciphers wep128
encryption vlan 402 key 1 size 128bit 7 blah blah transmit-k
ey
encryption vlan 402 mode wep mandatory
encryption vlan 401 key 1 size 128bit 7 blah blah transmit-k
ey
encryption vlan 401 mode ciphers wep128
ssid blah-blah-0
vlan 401
authentication open mac-address mac_methods
ssid blah-blah-1
vlan 403
ssid blah-blah-3
vlan 402
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
no preamble-short
channel 2462
station-role root
no cdp enable
dot1x reauth-period 60
dot1x client-timeout 65555
interface Dot11Radio0.401
encapsulation dot1Q 401 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.402
encapsulation dot1Q 402
ip helper-address 10.106.178.1
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface Dot11Radio0.403
encapsulation dot1Q 403
ip helper-address 10.106.179.1
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface FastEthernet0
no ip address
no ip unreachables
no ip route-cache
duplex auto
speed auto
ntp broadcast client
interface FastEthernet0.401
no ip unreachables
no ip route-cache
bridge-group 1
interface FastEthernet0.402
no ip unreachables
no ip route-cache
bridge-group 255
interface FastEthernet0.403
no ip route-cache
bridge-group 254
interface BVI1
ip address 10.10.17.126 255.255.255.128
no ip redirects
no ip unreachables
no ip route-cache
ip default-gateway 10.106.17.1
ip http server
ip http port 8080
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
/ivory/1100
ip http authentication aaa
ip radius source-interface BVI1
logging history debugging
logging trap debugging
access-list 700 permit 0002.78f4.a27c 0000.0000.0000
access-list 700 permit 0001.2480.eee9 0000.0000.0000
access-list 700 permit 000c.8500.00f2 0000.0000.0000
access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
radius-server host 10.106.17.12 auth-port 1812 acct-port 1813 key 7 blahblah
radius-server retransmit 3
radius-server authorization permit missing Service-Type
bridge 1 route ip
line con 0
line vty 5 15
end
Any ideas?
1 REPLY
Anonymous
N/A
Re: Can't Ping Wireless Clients
Enabling WEP could be one of the problems, even thuogh they are two different service. Try pinging after disabling WEP.
192
