Can't setup a Lobby Ambassador account??
I've just installed a new WLC4402 (50AP) and am trying to set up guest WLAN access.
So far I have a seperate VLAN and WLAN configured and have secured the VLAN to allow only access to the internet after web-auth.
I go to the 'Management> Local Management Users> New Page'
But the only types of account available are 'Read/Write' and 'Read Only', Should the 'lobby Ambassador' be listed here, or am I missing something?
All the best to all the Forum users for the season.
Dan
1 ACCEPTED SOLUTION
Re: Can't setup a Lobby Ambassador account??
Hi Dan,
It should be there if you are running 4.0+ software. If you are running 4.0+ then you could try adding the user via CLI to see if it's an option:
config mgmtuser lobby-admin
If you are running 3.2 or earlier, then that's the problem.
-Ben
Hi Dan,
-Ben
Thanks Ben,
I'll give that a try as soon as possible and let you know how I get on. I'm not sure of the software version, I'll check that out also.
Happy new year to all
Dan
Hi Ben,
Sorry for the delay in posting.
I upgraded the WLC4402 to the latest version of code and now all is resolved. Thanks for your help.
Regards, Dan
120
