02-09-2006 08:14 AM - edited 07-04-2021 11:37 AM
I have tried the tftp/telnet method. I have tried force-reload, overwrite and leave-old. None of them work however.
I tried the web interface, but It keeps saying software upgrade disrupted about 15 seconds in every time. I tried to use the tftp on the web interface but that doesn't work either. I tried a hardwire connection from a lap top directly into the access point, but I get the same result as the web interface. I turned off pop-up blocker on IE as well.
Any Suggestions? Thanks
02-09-2006 08:30 AM
Did this yesterday to an old AP1100. 1st of all, you will need a tftp server program, suggest tftp32 and is free via the internet. Place new image in the default folder for tftp32. doubleclick the tftp32 icon and the program will be running during the upgrade process. The method I use is an image overwrite. Your AP will be tested for memory allocation before the upgrade is performed. Use the following syntax:
ap#archive download-sw /overwrite tftp://10.0.0.10/c:/tftp32/c1100-k9w7-tar.123-4.JA.tar
you will need to use your clients ip address for the tftp://x.x.x.x statement and the directory where the new image is stored for the c:/tfpt32/c1100-xxxx-tar.xxx-x.xx.tar.
hope this helps...
02-09-2006 10:31 AM
Thanks but it didn't work. I have included a picture. Did I do something wrong.
02-09-2006 12:56 PM
only a minor mistake....you were attempting to do the archive command from "user" mode (ap>) instead of using priveleged exec mode (ap#). at the ap> type and enter the word enable....if you have a global password configured, then you'll have to enter it...if not...it should be username: Cisco password: Cisco
make the corrections and let me know how it goes.
02-10-2006 11:00 AM
I would like to personaly thank you. I think you saved my job!
