Community Member
Can you combine the throughput of 2 wireless bridges
I have one wireless bridge going to only one point, but the users are using up the bandwith. I need to get more some how. I would like to set up another point-to-point link, but I dont want to have spanning tree loops. Is there a way to get this done..... ????????
Community Member
Re: Can you combine the throughput of 2 wireless bridges
try a port channel using switches at each end or use routers with a load balancing protocol
Community Member
Go with a 100 Mb laser, whole systems go for $8K.
Community Member
I have 2 point to point links set up as a channel with a Cat 5509 on one end and 3548XL switch on other end. Has worked fine for 18 months at least.
The only problem that I have is I cannot telnet to bridges after setting up the channel. I have to break the channel in order to remotely manage bridges.
Haven't found a solution for that yet.
176
