Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Hall of Fame Super Silver
Can you hard code the speed and duplex on lightweight access points
I have a client that want to set the spped and duplex on the switch port. Is there a way you can configure the fastethernet port on a lightweight access point for speed and duplex.
-Scott
1 REPLY
Bronze
Re: Can you hard code the speed and duplex on lightweight access
Try this step
configure terminal
Enter global configuration mode.
Step 2
interface fastethernet0
Enter configuration interface mode.
Step 3
speed {10 | 100 | auto}
Configure the Ethernet speed. Cisco recommends that you use auto, the default setting.
Step 4
duplex {auto | full | half}
Configure the duplex setting. Cisco recommends that you use auto, the default setting.
Step 5
end
Return to privileged EXEC mode.
Step 6
show running-config
Verify your entries.
Step 7
copy running-config startup-config
188
