Cannot get VLANs across wireless bridge. Need Help Please!
I have 2 2950 switches and 2 1200 access points. I upgraded the ios to allow me to use them as bridges. I have the bridge setup just fine. I have created two vlans (1 and 5). I have them plugged into the switches and have the ports configured for switchport mode trunk. I cannot seem to get the vlan portion for work correctly. Can somebody please help. I have researched and researched and tried multiple things but nothing seems to works. Here is one of my access points.
version 12.3
no service pad
service password-encryption
hostname AP1
enable secret xxx
ip subnet-zero
no aaa new-model
dot11 ssid vlan1
vlan 1
infrastructure-ssid
dot11 ssid vlan5
vlan 5
dot11 network-map
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid vlan1
ssid vlan5
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
rts threshold 2312
antenna receive right
antenna transmit right
antenna gain 3
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.5
no ip route-cache
bridge-group 5
interface BVI1
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
end
1 ACCEPTED SOLUTION
Re: Cannot get VLANs across wireless bridge. Need Help Please!
I got mine working.
In the switch I issued the command
no spanning-tree vlan 50,98
Give it a try and let me know.
Silver
Hi Christopher,
do you have the vlan 5 created on the 2950?
Have a "sh vlan". In the list the VLAN ID 5 should appear. If not your VLAN database lacks the vlan 5.
I assume Vlan 1 runs without any problem?
Best regards,
Frank
Hi Frank,
Yes I have vlan 5 on the 2950, the sh vlan command verifies that. You are correct with saying that vlan 1 runs without any problems.
Silver
Hi Christopher,
do you have the following also setup on the AP connected switchports:
switchport trunk allowed vlan 1,5
Best regards,
Frank
Yes I do.
Well I take that back. I do not have switchport trunk encapsulation dot1q. That command does seem to exist with this 2950. I will try and upgrade the ios and see what happens.
Well I upgraded the IOS on the 2950 but I still cannot use that command, switchport trunk encapsulation dot1q...
I am trying pretty much the same thing. My 2950 keeps giving this message.
2960-tech-admin-50.2#
01:32:17: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/20 on VLAN0
098. Port consistency restored.
050. Port consistency restored.
01:32:18: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan i
d 98 on FastEthernet0/20 VLAN50.
01:32:18: %SPANTREE-2-BLOCK_PVID_PEER: Blocking FastEthernet0/20 on VLAN0098. In
consistent peer vlan.
01:32:18: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/20 on VLAN0050. I
nconsistent local vlan.
Although my config -very similar to yours- looks good.
Can you check to see if you are getting the same message in your switch?
Yea, I am getting same error message on my 2950s
Interesting - good to see I'm not the only one struggling.
Everything I have read says we are doing it correctly. I will attempt to run some debugs on the AP and switch.
I got mine working.
So you have your aps configured just like mine and on the 2950 switch, the port that you have the ap connected to, you have switchport mode trunk and then you issued the above command no spanning-tree on the appropriate vlans and now your able to pass traffic across your vlans over the wireless bridge? Is the above info, correct?
Pretty much. First I tryed enabling spanning tree everywhere - since the error message was a STP message. After a few iterations of the config, it ended up like this in the 2950.
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
and I can now pass traffic - all error messages are gone.
Thanks, I'll give it a try later this afternoon and post my results.
The config on the port connected to the AP/Bridge should be:
int fa0/x
It looks like the VLANS are configured for the SSIDs. Make sure that the switch is a member of the VTP domain (I'm guessing that it is acting in a client role; 'sh vtp stat').
On the connected switch issue the 'sh interface fa0/x trunk' to see the trunked vlans on the switchport. Also, the 'sh spanning-tree summary' will show vlans on the switch. If the vlan is not listed, check that spanning-tree is working for the vlan. If it isn't, issue the command 'spanning-tree vlan x', where x is the desired vlan. On the bridge 'sh vlan dot1q' will show vlan traffic.
Hope this helps. Please remember to rate helpful posts, thanks.
T
It was the command
that fixed my config.
Well, this still did not work for me. Still having trouble with traffic crossing the bridges on all vlans except the native vlan.
As a side note specific to this thread in the post. 2950's only support 802.1q trunking so when you enable the trunk on the switchport with 'switchport mode trunk', the trunk encapsulation automatically gets set to 1q.
Yea I did read after posting the reply. I blew away the configs on everything for about the 10th time, reconfigured everything and it started to function properly. I do not know what was going on with the configs that I had. But it all works now. I really appreciate everybody's input on this.
344
