Cant console to WISM in a 6500
omarmontes
Hi guys, im having some trouble here. I dont think my cards are faulty (4 cards in 2 6500 switches), it would be a great coincidence.. but here is my problem:
I connect directly to my WISM cards, boot them (insert them), I see it turning on, enabling services, and as soon as the "username:" prompt apears, the Status led turns off and I lose console. This happens with every card, so I guess theres something wrong im doing.
Do you guys know any clue?
Software:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Module:
Mod Ports Card Type                              Model              Serial No.
  1   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAL1514AGNU
  2   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAL1518CN5J
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAL1518CQDW  2.2    Ok
  2  Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAL1518CQE4  2.2    Ok
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  f866.f2b2.1200 to f866.f2b2.120f   2.4   12.2(14r)S5  12.2(33)SXI6 Ok
  2  f866.f2b2.1480 to f866.f2b2.148f   2.4   12.2(14r)S5  12.2(33)SXI6 Ok
Thanks in advance
Omar M.
21 Replies 21
omarmontes
By the way, issuing the "session slot 1 pro 1" didnt work either
Stephen Rodriguez
Can you pull a "show wism status" ?
For the session to work, you need to have configured the "wism service-vlan < vlan >" and a dhcp scope for it.  Then you should be able to session in through the fabric.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
omarmontes
The status says serive port online. But 0.0.0.0 ips. i already enabled dhcp and service port vlan, just as documentation says. :S
can you post the dhcp scope,l3 SVi and the wism commands, and a show vlan brief?
HTH,
Steve
Sure!
ip dhcp excluded-address 192.168.10.1 192.168.10.2
ip dhcp pool wism-service-port
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
wism service-vlan 192
wism module 1 controller 1 allowed-vlan 102,192,2001,2003,2005,2007,2009,2011
interface Vlan192
description WiSM Service Port Gateway or Management Interface on CAT6K
ip address 192.168.10.1 255.255.255.0
And here is the status:
Service Vlan : 192, Service IP Subnet : 192.168.10.1/255.255.255.0
      WLAN
Slot  Controller  Service IP       Management IP    SW Version  Status
1     1           0.0.0.0          0.0.0.0                      Service Port Up
Anyway.. I SHOULD be able to console directly to it right?
Stephen Rodriguez
yes you should be able to console directly in. So long as you are set for 9600/none/8/1 with no flow control.
For the fabric dude issue the command VLAN 192. In the 6k you need to explicitly create the L2 VLAN
HTH,
Steve
Yeap, VLAN 192 was already created...
anything else I could try? Could it be an IOS problem or something?
what chassis are you using, 6509/6513?
HTH,
Steve
6509E
Cards are in Slot 1 and 2, in both 6500
Can you kill the power to slot 2, and see if the WiSM in slot 1 will come up?  Could be a lack of power, but I would think it wouldn't power up at all, but you never know.
no power enable slot 2 IIRC
HTH,
Steve
Nope:
  2  f866.f2b2.1480 to f866.f2b2.148f   2.4   12.2(14r)S5  12.2(33)SXI6 PwrDown
6500-1#session slot  1 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 0.0.0.0 ...
% Connection timed out; remote host not responding
show power status all:
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-SVC-WISM-1-K9    163.80  3.90   163.80  3.90  on    on
2    WS-SVC-WISM-1-K9    163.80  3.90     -     -     off   off (User Request)
The card is getting the power it requested, still no luck.
Ok, so still not getting DHCP to the service port.  You'll want to debug the DHCP process, and reset the card to see if we can see why it's not happening.
HTH,
Steve
6500-1#show debug
DHCP server packet debugging is on.
DHCP server event debugging is on.
DHCPC:
  DHCP client activity debugging is on (detailed)
*Dec 20 18:26:19.883: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
*Dec 20 18:26:20.535: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
No DHCP messages
