Cant console to WISM in a 6500
omarmontes
Hi guys, im having some trouble here. I dont think my cards are faulty (4 cards in 2 6500 switches), it would be a great coincidence.. but here is my problem:
I connect directly to my WISM cards, boot them (insert them), I see it turning on, enabling services, and as soon as the "username:" prompt apears, the Status led turns off and I lose console. This happens with every card, so I guess theres something wrong im doing.
Do you guys know any clue?
Software:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Module:
Mod Ports Card Type                              Model              Serial No.
  1   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAL1514AGNU
  2   10  WiSM WLAN Service Module               WS-SVC-WISM-1-K9   SAL1518CN5J
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAL1518CQDW  2.2    Ok
  2  Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAL1518CQE4  2.2    Ok
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  f866.f2b2.1200 to f866.f2b2.120f   2.4   12.2(14r)S5  12.2(33)SXI6 Ok
  2  f866.f2b2.1480 to f866.f2b2.148f   2.4   12.2(14r)S5  12.2(33)SXI6 Ok
Thanks in advance
Omar M.
21 Replies 21
Where did the WiSM you got come from?  The service port should be DHCP by default, but I have seen them act up as well.
Are you able to hit the front edge with 960/none/8/1 flow controll off?
If not, I'd open a TAC case and get them in to take a look and possible RMA.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Where did it come from? directly from Cisco if thats what you mean. Still no luck with the console port in the card . You can see the boot process but as soon as the prompt apears you lose conection.
I am having the same exact problem with a couple of WISM mdoules, how was this solved?
Jawad
It was a stupid setting in our terminal software :S
Isn't is supposed to be 9600-8-N-1 setting?
I actually have the same problem, tried different terminal softwares with no luck
Jawad
We had to disable some XOR or something feature in SecureCRT enabled by default. Just make sure to disable everything not needed.
flowcontrol should be set to none.
Steve
HTH,
Steve
