CAP-2602 not registering with WLC4402
I have a WLC model 4402 running 7.0.235.3. I am trying to make a CAP2602 to join the WLC but it is unable to. Doesn't the 4402 with this software support the 2602? The WLC has a license for 12 AP's, only 9 in use. Currently there are only AIR-LAP1131 connected to the WLC.
The debug on the WLC shows this;
*spamReceiveTask: Aug 14 08:16:07.133: 00:3a:9a:ab:c0:74 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '29'
*spamReceiveTask: Aug 14 08:16:07.133: Ethernet Source MAC (LRAD):      00:3A:9A:AB:C0:74
**spamReceiveTask: Aug 14 08:16:07.134: 00:3a:9a:ab:c0:74 Discarding discovery request in LWAPP from AP supporting CAPWAP
The CAP2602 gets its IP from the switch, and keeps on changing IP's all the time. I am able to ping it until it changes IP.
Everyone's tags (2)
I can answer this myself, after some checking I found out that the last software-version for WLC4402, which is 7.0.240, does NOT support the 2602 access-points according to this document,
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_240_0.html#wp784295
Hall of Fame Super Gold
2600 AP requires firmware 7.4.X.
7.4.X code is supported on the 2504/5508/WiSM-2 and later.  It's not supported in 4400/WiSM-1.
As per your query i can suggest you the following solution-
The controller software is factory installed on your controller and automatically downloaded to the access points after a release upgrade and whenever an access point joins a controller. We recommend that you install the latest software version available for maximum operational benefit.
Change the IP address of the management interface.
Hope this will help you.
1413
