CAPWAP/LWAPP config
Is there a way to change the username/password for all the APs connected to a WLAN in one move or command?
Normally I would go into the individual APs and change the controllers in the WLAN GUI.
But there's got to be a better way, seeing that I have 30+ APs to manage.
Thank you.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: CAPWAP/LWAPP config
You can. Under the wlc wireless tab on the left under access points. Global Configuration is what you want.
WIreless | Access Points | Global Configuration
Scott Fella
Sent from my iPhone
-Scott
CAPWAP/LWAPP config
Normally I would go into the individual APs and change the **controllers** in the WLAN GUI.
**APs**
Meant to say AP not controller
Scott Fella
Sent from my iPhone
-Scott
CAPWAP/LWAPP config
Wow, thanks a bunch!  Saved me a ton or tedious clicking.
Thank you.
286
