cb21ag, windows 2000, novell client32 4.8, and leap
We have two problems.
1) After installing the card and software we get a winlogon.exe failure at boot followed by a quick windows bluescreen and reboot. This continues until you go into safemode and remove the software/drivers. If I uninstall Novell client32 and then re-install I no longer have this problem. As soon as I re-install client32 the problem occurs again.
2) If I leave client32 off I do not get a dhcp address. I show associated in the AP but the DHCP fails.
Any ideas?
Anonymous
N/A
Re: cb21ag, windows 2000, novell client32 4.8, and leap
Sounds like you are hitting the bug CSCed84100
Hall of Fame Super Silver
I followed up with our development engineers and he said that the release for the code that fixes CSCed84100 is targeted for June 18th.
-Scott
I just installed the latest Win-Client-802.11a-b-g-Ins-Wizard-v1.exe and observered continual reboots too. After booting in Safe mode I removed all previous versions and the thing installed, but the card locks up my PC whenever its inserted into the PC. Ugh!!
I had the same issue with XP. I had to boot into safe mode and I then uninstalled just the Utility but kept the driver. I rebooted and the ran through the wizard installing the Utility. It works now.... Had problems on two XP machines. I can't get Windows 2000 to work.... blue screen all the time.
-Scott
-Scott
-Scott
232
