CCKM and LEAP issues
I'm wondering if CCKM requires that I have a WDS?
I've configured one of our 1200 series access points to do Local Radius authentication which works when I use 802.1x as the Security Option and select LEAP as the 802.1x EAP type on the client side (ADU version 2.6).
When I change the Security Option to WPA/WPA2/CCKM and select LEAP as the EAP type it fails to Authenticate.
On the AP side I've configured the Cipher to use CKIP-CMIC. In the SSID Manager I've configured the Client Authentication Settings to use Open Authentication with EAP and Network EAP witn no additions.
Under the Key Management I've configured Optional and checked CCKM. (I've also tried Mandatory with the same results).
Anyone have any suggestions?
1 REPLY
Silver
Re: CCKM and LEAP issues
There are four versions of the Cisco Compatible specification: Version 1 (V1), Version 2 (V2), Version 3 (V3), and Version 4 (V4). Each version builds upon its predecessors. With a few exceptions, every feature that must be supported in one version also must be supported in each subsequent version.
http://www.cisco.com/warp/public/765/ccx/versions_and_features.shtml
133
