CCKM and WPA on AP
How to force the Cisco ABG client card (PCMCIA CB21AG-A-K9) to associate in Access Point using CCKM as Key Management?
Note that the CCKM and WPA are checked as Mandatory in SSID Manager configuration.
Re: CCKM and WPA on AP
Uncheck WPA....
Thanks but that would disconnect other wireless user using intel 2200BG wireless card. I want to preserved other eap-fast users that connected using WPA. Would it be possible?
Read this old post....If you have any other further concers I would suggest opening a TAC case...
Posted by: herbert.aichhorn - Mar 16, 2005, 5:43am PST
I had the same issue (this fact is not documented from the cisco side):
cckm can be concurrently configured on the ssid but is not intended to be a addition. the cb21ag is associating always with wpa when enabled both wpa and cckm on the ssid.
cckm with fsr works correctly with both cb21ag card and pcm352 when only cckm is enabled on the ssid.
the workaround for not cckm capable tkip-clients is to set up a second ssid for wpa-keymanagement.
181
