CHALLENGE: Can you configure DHCP server on IOS-AP for multiple VLANs ?!
we are talking here about autonomous AP in latest 12.4 IOS release.
I know well how to create a dhcp pool on an AP and distribute addresses to clients when you have a single interface (radio and Ethernet).
But what can we do when we want to create multiple DHCP scope for multiple radio sub-interfaces for multiple VLANs at the end!!!???
It tried fixing an IP addresse in the sub-interface, and using it as DHCP server with the standard DHCP scope definition, but no way, it does not work.
And when searching more on CCO, I cannot find any doc solving that case.
Thanks for help.
Re: CHALLENGE: Can you configure DHCP server on IOS-AP for multi
create a vlan for each ssid and trunk using a subinterface for each vlan.
Sorry Jeremy but that's what I already done since I need several SSID/VLANs.
Here below the main extract of the config.
Then if I create a DHCP Scope for each VLAN, I do not have a way to ask the AP to assign scope30 to VLAN30, scope50 to VLAN50, etc...
It only work if you define 1 single scope matching the same subnet as the BVI int!
dot11 vlan-name Employee-WiFi vlan 30
dot11 vlan-name Guest-WiFi vlan 50
dot11 ssid FAGUEST
vlan Guest-WiFi
max-associations 10
authentication open
authentication key-management wpa
wpa-psk ascii ------------
dot11 ssid FALAN
vlan Employee-WiFi
max-associations 10
authentication open eap EAP
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan Employee-WiFi mode ciphers aes-ccm
encryption vlan Guest-WiFi mode ciphers aes-ccm tkip
ssid FAGUEST
ssid FALAN
BLABLABLA...
BLABLABLA...
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
no cdp enable
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface Dot11Radio0.50
encapsulation dot1Q 50
no ip route-cache
no cdp enable
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
bridge-group 50 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.30
no ip route-cache
bridge-group 30
interface FastEthernet0.50
no ip route-cache
bridge-group 50
interface FastEthernet0.99
encapsulation dot1Q 99 native
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface BVI1
ip address 10.74.101.208 255.255.255.0
no ip route-cache
ip default-gateway 10.74.101.1
bridge 1 route ip
Like the wire LAN DHCP,you must creat BVI
for every WLAN/VLAN.
For example:
interface BVI 30
ip address x.x.x.x **must belong dhcp scope30
interface BVI 50
ip address x.x.x.x **must belong dhcp scope50
maked sure that the uplink port is configuried as a trunk and that the vlans are allowed. also you need to have those vlans on the uplink switch and so on till you get to your core. you might have to add helper address on the vlan interfaces so that those interfaces know wher to send dhcp requestes
Hi jeremy,
do you mean I should configure on the 'int vlan x' of the switch a 'ip helper-address' pointing to the AP's BVI ip address?
And just defining a scope in the AP that matchs the same subnet as the switch IP address that relay the DHCP request?
In fact you are proposing to let request goes out of the AP to go back again in the AP for proposal, right ?
Green
On the AP itself? NO, you can't.
A network-based DHCP server (Windows or *nix) will work OK, assuming you have the trunking and switches configured properly.
The AP-based RADIUS also has limited functionality.
APs have just little teeney tiny CPUs (compared to a real server) and limited memory and storage. Aside from handing traffic to/from the wired/wireless domains, it's not meant to handle enterprise server functionality.
Single DHCP service, like for a small or temporary location, no problem. Multiple DHCPs domains ... get a server.
Good Luck
Scott
153
