I'm trying to use the http gui to change the channel used on my AP, but cannot make it happen. I've
tried changing the dropdown back from Least Congested to a specific channel, no luck. And I've tried limiting the channels used in the Least Congested search, no luck. Both just bring back a blank screen, at this URL http://{APADDRESS}/channel+least-congested+2417%5Binterface%2fDot11Radio0%5D%0Awrite+memory+quiet%0A or http://{APADDRESS}/channel+2417%5Binterface%2fDot11Radio0%5D%0Awrite+memory+quiet%0A
I'm fighting lost connectivity when two radios (all are 1310s) are in direct opposite directions of my main multipoint radio, facing each other. When I unplug either radio, the other works fine. I'm unable to change the channel on either radio, and cannot upgrade to latest IOS either (my main multipoint radio did accept the upgrade, to version c1310-k9w7-tar.124-21a.JY. Problem radios are running version c1310-k9w7-tar.123-8.JA
TIA
gene
