Changing native VLAN on non-root bridges
I have quite a few 1310 Bridges setup in point to multipoint configuration with a root bridge with a sector antenna at the campus network and remote sites connecting in. I have multiple VLANs trunked onto one SSID, this allows for having multiple vlans in use at the remote site. The problem is I want to configure some remote site bridges with a different native vlan than the standard allowing me to plug the client directly into the injector and eliminate the need for a vlan aware switch. I have tried to configure the the "encapsulation dot1q VLAN# native" but this swaps the bridge group on the subinterface to a bridge-group 1 .
! Last configuration change at 01:23:08 UTC Tue Sep 15 2009 by Cisco
! NVRAM config last updated at 01:23:09 UTC Tue Sep 15 2009 by Cisco
version 12.4
no service pad
service password-encryption
no aaa new-model
dot11 ssid Cisco-24
vlan 1
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid optional
wpa-psk ascii test
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 901 mode ciphers aes-ccm tkip
encryption vlan 902 mode ciphers aes-ccm tkip
encryption vlan 904 mode ciphers aes-ccm tkip
ssid Cisco-24
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0
station-role non-root bridge
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.901
encapsulation dot1Q 901
no ip route-cache
bridge-group 255
bridge-group 255 spanning-disabled
interface Dot11Radio0.902
encapsulation dot1Q 902
no ip route-cache
bridge-group 254
bridge-group 254 spanning-disabled
interface Dot11Radio0.904
encapsulation dot1Q 904
no ip route-cache
bridge-group 253
bridge-group 253 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.901
no ip route-cache
bridge-group 255
interface FastEthernet0.902
no ip route-cache
bridge-group 254
interface FastEthernet0.904
no ip route-cache
bridge-group 253
interface BVI1
ip address 10.0.0.100 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community misdept RO
bridge 1 route ip
line con 0
line vty 0 4
login local
end
278
