changing to wireless
Hi, we have a Linksys WRT54G,(which we use for both LAN, but wireless enabled obviously) and i need to implement a wireless solution for the ground floor of my office. Can anyone recommend cisco wireless equipment that will suit my purpose(including site survey devices). Most users will be charged for using the wireless.
Thank you.
Daniel.
1 REPLY
Silver
Re: changing to wireless
Mail to the followign link for the product support with linksys.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/ask.php?p_icf_3=1
If WEP is required between devices from different manufacturers, configure all such devices to use 40-bit WEP.
The IEEE 802.11b specification defines only 40-bit Wired Equivalent Privacy (WEP).
Cisco and other vendors have independently extended the specification by implementing their own versions of 128-bit WEP, which may not be compatible with each other.
90
