04-30-2010 01:18 PM - edited 07-03-2021 06:46 PM
Hello Everyone,
I have a AP 1250 and I would like to channel bond with the 5-GHz 802.11n radio; to get more throughput. I have found some articals how to do this, but it's for the non autonomous AP GUI setup. Does anyone have the IOS commands to use and maybe an doc to go with it? Thanks
05-02-2010 02:42 PM
HTML into your AP, go to Netowork Interfaces, 5GHz radio and click into the Settings Tab.
Go down to the "Channel Width" dropdown menu and choose "Above 40MHz".
For "n" to work, you need to have WPA2/AES or open authentication to work.
Hope this helps. Please don't forget to rate our posts.
05-03-2010 05:51 PM
Thanks for the replay; the AP is currently using above 40MHZ and WPA2/AES. And that's were I'm standing on this channel bonding.
