Channel on a AP4800E v8.80
I got an AP4800E v8.80 and i want to force a channel on that AP and i would like to know how to do it
Re: Channel on a AP4800E v8.80
AP4800 is same as AP340..Plug the ip address in the web browser like http:// 1.1.1.1
Where 1.1.1.1 is ip address of AP. After that Click on "Setup" and under "Network Ports" and "AP Radio" click on "Hardware". You will see "Default Radio Channel:" config..whre you can select channel..Pl. visit following url for more information
http://cco/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch3.htm#76429
Jonathan,
I would rather believe that 340 config is closer to 350 config.
On the AP4800E: (through Telnet or Serial port )
From main menu,
Go to Configuration (1)
Go to Radio (1)
Go to frequency (5)
select the frequency you want to use... and that's it.
Multiple ESC to get back to main menu.
Through HTTP,
on the left side, click "Allow config changes" and you will find what you are looking for.
Guy
135
