Channels 34, 38, 42, 46
while using scanning utilities with Cisco card [AIR CB21AG-A-K9] not supports the channels 34, 42, 50, 58.
Is there any settings ? How to configure the card for these channels.
Is it possible to configure the 'regulatory domain settings: country code' for cisco card, thru' any configuration tool.
I found NetGear Card supports Frequency range list (in MHz)
5130 - 5670
5150 - 5650
5120 - 5700
5745 - 5825
2312 - 2372
2412 - 2472
2484 - 2484
2512 - 2732
But, first set of frequency range is missing in the CISCO card. (channels 32, 26, 42, 46). [Country code is 0x1ff]
I tried some different country settings & roaming options, but the 1st set of freq. is missing.
Silver
Re: Channels 34, 38, 42, 46
Hi Nagarajan
Here you are the channels and frequencies supported in that card:
http://www.cisco.com/en/US/products/hw/wireless/ps4555/module_installation_and_configuration_guides_chapter09186a00805063b4.html
It looks like channels 34 and 42 are only supported in Japan's regulatory domain and cahnnels 50 and 58 are not supported.
Hope this helps
Thanks for your reply.
I want to know how to configure the card for Regulatory doamin - CountryCode to 'Japan'.
Because my scanning utility allows ch-14 (which is in 'Japan' domain only) with same cisco card
Cisco card channels for country code: 0x1ff
36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,149,153,157,161,165,
1,2,3,4,5,6,7,8,9,10,11,12,13,14,
Netgear card channels for same country code: (0x1ff), observe the channels. 34,38,42,46, 50, 58 which is missing in Cisco
34,42,50,58,38,46,36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,149,153,157,161,165,
Even for Japan Country code cisco card not report the mentioned channels
150
