05-07-2012 09:14 AM - edited 07-03-2021 10:07 PM
hello,
I have a question, I have an ap (cisco 1130) that began to get the status light flashing orange and light Ethernet and radio are off.
I did a factory reset and it was ok ... past 3 days the problem has happened again ...
I changed the ap with a new but the situation remained ...
I tested the wiring and everything is ok.
the switch port is set up correctly
may be what??
problem switch??or problem ap??
05-07-2012 03:36 PM
Console into the WAP and restart the WAP. Please post the entire bootup sequence.
05-08-2012 04:46 AM
I leave the logs requested:
Xmodem file system is available.
flashfs[0]: 10 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6278144
flashfs[0]: Bytes available: 9720832
flashfs[0]: flashfs fsck took 33 seconds.
Base ethernet MAC Address: 00:23:33:bc:80:4c
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 1515 milli-seconds to complete
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-rcvk9w8-mx"...############################################ ################################################################################ ################################################################################ ######################################################
File "flash:/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.4(21a)JA2, RELE ASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Nov-09 18:17 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 10 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6278144
flashfs[1]: Bytes available: 9720832
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
%Error opening flash:/info (No such file or directory)
A summary of U.S. laws governing Cisco cryptographic products may be found at:
%Error opening flash:/c1130-rcvk9w8-mx/info (No such file or directory)cisco AIR -AP1131G-E-K9 (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1251Q08N
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:33:BC:80:4C
Part Number : 73-11587-02
PCA Assembly Number : 800-30422-01
PCA Revision Number : B0
PCB Serial Number : FOC124839B0
Top Assembly Part Number : 800-29578-02
Top Assembly Serial Number : FCZ1251Q08N
Top Revision Number : A0
Product/Model Number : AIR-AP1131G-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:05.947: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 120 messages)
capwap_read_version_info: Info file flash:/info not find
*Mar 1 00:00:08.225: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.252: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:08.280: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 1 00:00:09.225: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0, changed state to down
AP0023.33bc.804c>
AP0023.33bc.804c>
AP0023.33bc.804c>
*Mar 1 00:00:37.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:00:47.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
AP0023.33bc.804c>
*Mar 1 00:00:57.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:07.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:10.222: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Mar 1 00:01:17.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:27.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
AP0023.33bc.804c>
AP0023.33bc.804c>
AP0023.33bc.804c>
*Mar 1 00:01:37.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:47.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:57.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:07.034: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
I dont understand the logs, but i see :
there is power problem with the power line wap and ip
I report the fault wap???
But already installed another wap and changed the switch port and the problem ended...
05-08-2012 04:26 PM
Errrr ...
The bootup shows OK with me. Are you suppose to operate this WAP in controller-based or autonomous?
05-14-2012 10:11 AM
What problems do you think is it?
05-14-2012 10:18 AM
Console into the ap, reboot the ap and post the complete output.
Scott Fella
Sent from my iPhone
05-15-2012 09:48 AM
hello,
I connect the console in to the WAP and then reboot the result of the bootup is as follows:
flashfs[0]: 26 files, 8 directories
flashfs[0]: Bytes used: 6858240
flashfs[0]: Bytes available: 9140736
flashfs[0]: flashfs fsck took 31 seconds.
Base ethernet MAC Address: 00:24:97:6e:2c:e2
Reset done!
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
Loading "flash:/c1130-k9w8-mx.124-23c.JZ/c1130-k9w8-mx.124-23c.JZ"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1130-k9w8-mx.124-23c.JZ/c1130-k9w8-mx.124-23c.JZ" uncompressed and installed, entry point: 0x3000
executing...
cisco Systems, Inc.
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JZ, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 06-Apr-11 15:01 by prod_rel_team
flashfs[1]: 26 files, 8 directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 6858240
flashfs[1]: Bytes available: 8882688
Radio0 present A506 7100 E8000000 A0000000 80000000 3
Radio1 present A506 6700 E8000100 A0040000 80010000 2
cisco AIR-LAP1131AG-E-K9 (PowerPCElvis) processor (revision B0) with 25590K/7168K bytes of memory.
Processor board ID FCZ1317Q102
LWAPP image version 7.0.98.218
2 802.11 Radio(s)
Base ethernet MAC Address: 00:24:97:6E:2C:E2
Part Number : 73-8962-14
PCA Assembly Number : 800-24818-13
PCA Revision Number : A0
PCB Serial Number : FOC13142PXW
Top Assembly Part Number : 800-29144-03
Top Assembly Serial Number : FCZ1317Q102
Product/Model Number : AIR-LAP1131AG-E-K9
*Mar 1 00:00:05.864: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:07.480: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:09.066: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar 1 00:00:09.154: %LWAPP-3-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar 1 00:00:09.155: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messages)
*Mar 1 00:00:09.184: status of voice_diag_test from WLC is false
*Mar 1 00:00:11.294: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:11.358: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:11.358: %SNMP-5-COLDSTART: SNMP agent on host CC-P2-AP4 is undergoing a cold start
*Mar 1 00:00:11.437: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 1 00:00:11.615: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:11.615: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:11.615: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:00:11.877: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:00:11.877: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:12.297: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar 1 00:00:12.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:12.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:00:30.265: status of voice_diag_test from WLC is false
*Mar 1 00:00:30.308: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:00:40.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:00:41.348: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar 1 00:00:50.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:00.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:10.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:14.626: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Mar 1 00:01:14.665: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:14.703: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:15.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:01:15.665: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:20.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:30.348: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:30.348: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:01:40.356: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:01:50.356: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:00.356: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:10.356: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:20.356: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:20.356: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:02:30.359: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:40.359: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:02:50.359: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:03:00.359: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:03:10.359: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:03:10.359: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:03:20.362: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:03:30.362: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
I was checking another thing, usually the switches we use here in my work supports a maximum of 14W per port or 15.4w, this wap is consuming 15.2w
Is this the problem??
the strange to me is that,in this same sw I have several WAP and they all use 12.2w
05-15-2012 10:16 AM
I remembered to configure cdp in the switch port, but the problem continued ...
I have to activate the cdp in WAP??
05-15-2012 03:41 PM
WTF ... This was taken from my request for you to bootup the WAP and post the output.
This is the output taken when Scott asked you for the same thing.
So the question is this: What is plugged in to the FastEthernet0 interface of the WAP?
If it's a Cisco switch, can you specify EXACTLY the model?
05-16-2012 01:57 AM
yes it's a cisco switch.
WS-C3560-48PS-S
05-16-2012 02:09 AM
WS-C3560-48PS-S
Just want to make sure that the copper ports are non-GigabitEthernet right?
If this is so, do you have a 2960/2960S, 3560G (or better) or 3750G (or better) that you could "use"? You don't need PoE. I just need you to run a TDR test using the switch models I've mentioned.
05-16-2012 08:54 AM
hello,
i already solved the problem, it's very silly
at the time we tested the network cables that will have the rack, etc. and apparently the pairs they were all ok, today I returned to make sure the cable 4 or 5 times and failed for some reason the cable 6 (power) ... but so awesome failed once.
I see the cable and the same panel installed okay, but the middle plug is loose, it makes poor contact, and sometimes it works, others do not ...
I thank all the help;)
