cisco 1130AG Access point's radio will get down frequently?
Dear Friends,
One of my Wi-Fi site, having cisco_1130AG access points nearly 110nos
as of now i installed 80nos, after installing, in out off 80nos nearly 12nos of APs's radio is showing down.
Again i reset and re-configure then it is working fine,
is there any readio (802.11g/a) problem in this model?
if there is a problem with radio, how to fix ?
Srinivas. N
Thanks & Regards, Srinivas. N.
Everyone's tags (6)
Hall of Fame Super Silver
Re: cisco 1130AG Access point's radio will get down frequently?
I don't know of any issue, but is the autonomous or lightweight access points. It seems like you have a workaround though.
-Scott
Hall of Fame Super Gold
More information please.
Is your WAP in autonomous or controller-based IOS?
Can you post the entire bootup process of the WAP that is exhibiting this sort of behaviour?
User Access Verification
Username: cisco
Password:
LEVEL-0_CONHALL2_002>en
Password:
LEVEL-0_CONHALL2_002#sh ver
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(21a)JA1, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:36 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (
fc2)
LEVEL-0_CONHALL2_002 uptime is 2 weeks, 3 days, 21 hours, 8 minutes
System image file is "flash:/c1130-k9w7-mx.124-21a.JA1/c1130-k9w7-mx.124-21a.JA1
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1131AG-N-K9    (PowerPCElvis) processor (revision C0) with 24566K/81
92K bytes of memory.
Processor board ID FGL1511V14P
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:4D:77:56
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : B0
PCB Serial Number                    : FOC15091P6K
Top Assembly Part Number             : 800-29230-02
Top Assembly Serial Number           : FGL1511V14P
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1131AG-N-K9
Configuration register is 0xF
1.  Please post the "sh logs".
2.  Reboot the WAP and post the entire bootup process.
Is it just the RADIO resetting or the AP??
Please provide show tech from the AP to proceed further!!
Surendra
Hello Srinivas,I believe that
Hello Srinivas,
I believe that you might have already found the solution. - Ios upgrade.
There is bug in version 124-21a.JA1, which causes radio interface to be reset status.
727
