Cisco 1142N AP - Upgrade gone really wrong
Hi everyone,
I have run into a major issue with an autonomous Cisco 1142AP. We were in the midst of a firmware upgrade when something went wrong and caused the AP to reboot in an error mode. Basically the unit was flashing Blue, amber, red. We unmounted the unit from the wall, connected to the console, and it would now only flash red over and over.
We pulled out the cisco guides and performed a factory reset on the unit. This still does not work. and the contents of our flash directory is empty. All we get is a ROMMON AP prompt on the unit. If I issue a set command, I can see the default settings for IP, netmask, etc.
I cannot access the unit via the network, even after setting IP info and matching it up to my laptop. Since I have no network connectivity, I can't TFTP a new IOS file to the unit.
I am stumped. Any ideas how to get the config as if it was out of the box, or an alternate way to TFTP to the unit?
Here is a summary of what I get when I factory reset:
using  eeprom values
WRDTR,CLKTR: 0x87000800 0x40000000
RQDC ,RFDC : 0x80000035 0x00000209
using ÿÿÿÿ ddr static values from serial eeprom
ddr init done
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000035, 0x00000209
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 32383488
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 70:81:05:ec:21:d7
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
button is pressed, wait for button to be released...
button pressed for 69 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
I then run a set command
ap: set
DEFAULT_ROUTER=10.0.0.1
ENABLE_BREAK=yes
IP_ADDR=10.0.0.1
MANUAL_BOOT=no
NETMASK=255.255.255.224
PRODUCT_MODEL_NUMBER=AIR-LAP1142N-A-K9
RELOAD_REASON=58
ROM_PERSISTENT_UTC=1326908306
TERMLINES=0
TFTP_SERVER=10.1.70.250
ip_ADDR=
tftp=
ap:
Notice the lines in red, I must have typed someting incorrectly. How do I remove this?
PS: Now once the unit boots after being reset, I cannot even type in the CLI. Someting majorly screwed up here.
Can the bootstrap be reinitialized?
Hall of Fame Super Gold
Re: Cisco 1142N AP - Upgrade gone really wrong
Unfortunately I had followed that portion of the procedure but I was unsuccessful. Unfortunately I could not connect to the unit at all.
What bothers me now is I cannot type anything in the CLI after I boot up, either normally, by interupting the boot, or by performing a reset.
Edit: I am now able to type in the CLI, but there is also kinds of bizarro information when I run the set command. Is there a way to clean up this set config? Also, is there any other mechanism to transfer the IOS image other than TFTP. Like I said, I can't connect to the unit via network, only console.
ap: set
ABLE_BREAK=yes
ANUAL_BOOT=no
ENABLE_BREAK=yes
ERMINES=ÿÿÿÿÿÿÿûÿÿÿ÷ÿÿÿóÿÿÿïÿÿÿëÿÿÿçÿÿÿãÿÿÿßÿÿÿÛÿÿÿ×ÿÿÿÓÿÿÿÏÿÿÿËÿÿÿÇÿÿÿÃÿÿÿ¿ÿÿÿ»ÿÿÿ·ÿÿÿ³ÿÿÿ¯ÿÿÿ«ÿÿÿ§ÿÿÿ£ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ{ÿÿÿwÿÿÿsÿÿÿoÿÿÿkÿÿÿgÿÿÿcÿÿÿ_ÿÿÿ[ÿÿÿWÿÿÿSÿÿÿOÿÿÿKÿÿÿGÿÿÿCÿÿÿ?ÿÿÿ;ÿÿÿ7ÿÿÿ3ÿÿÿ/ÿÿÿ+ÿÿÿ'ÿÿÿ#ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
                                                             ÿÿÿÿÿà
ETMASK=255.255.0830
IP_ADDR=10.0.0.1
MANUAL_BOOT=no
MLIES=0
NABLE_BREAK=yes
NUAL_BOOT=no
P_ADDR=10.0.0.1
RELOAD_REASON=58
TERMLINES=0
TMASK=255.255._06
_ADDR=10.0.0.1
ip_ADDR=
set=ÿÿÿÿÿÿÿûÿÿÿ÷ÿÿÿóÿÿÿïÿÿÿëÿÿÿçÿÿÿãÿÿÿßÿÿÿÛÿÿÿ×ÿÿÿÓÿÿÿÏÿÿÿËÿÿÿÇÿÿÿÃÿÿÿ¿ÿÿÿ»ÿÿÿ·ÿÿÿ³ÿÿÿ¯ÿÿÿ«ÿÿÿ§ÿÿÿ£ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ{ÿÿÿwÿÿÿsÿÿÿoÿÿÿkÿÿÿgÿÿÿcÿÿÿ_ÿÿÿ[ÿÿÿWÿÿÿSÿÿÿOÿÿÿKÿÿÿGÿÿÿCÿÿÿ?ÿÿÿ;ÿÿÿ7ÿÿÿ3ÿÿÿ/ÿÿÿ+ÿÿÿ'ÿÿÿ#ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
                                                         ÿÿÿÿÿà
tftp=
ap:
Try using a different client.
909
