Community Member
Cisco 1200 series upgrade failure
I have a Cisco 1200 Series (AIR-AP1231G-A-K9) access point, I have been upgrading these models to lightweight mode but are having issues with one in particular, this access point keeps "rebooting" itself, I am assuming that the upgrade faild, how can I get the access point upgraded?
Here is a capture.
Cisco IOS Software, C1200 Software (C1200-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:41 by alnguyen
Image text-base: 0x00003000, data-base: 0x00359FC0
Initializing flashfs...
flashfs[1]: 4 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 1862656
flashfs[1]: Bytes available: 5878784
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision B0) with 15038K/1336K bytes of memory.
Processor board ID FTX0914J0Z1
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:13:7F:E2:34:DB
Part Number : 73-8704-08
PCA Assembly Number : 800-23211-09
PCA Revision Number : A0
PCB Serial Number : FOC09100NH1
Top Assembly Part Number : 800-23304-08
Top Assembly Serial Number : FTX0914J0Z1
Top Revision Number : A0
Product/Model Number : AIR-AP1231G-A-K9
Press RETURN to get started!
*Mar 1 00:00:04.505: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:05.442: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:06.442: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
ap>
ap>
*Mar 1 00:00:14.441: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:23.516: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:23.544: LWAPP_CLIENT_ERROR_DEBUG: lwapp_crypto_init_ssc_keys_and_certs no certs in the SSC Private File
*Mar 1 00:00:23.544: lwapp_crypto_init: PKI_StartSession failed
*Mar 1 00:00:23.698: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: FAILED CRYPTO INIT.
*Mar 1 00:00:23.698: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
flashfs[0]: 4 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1862656
flashfs[0]: Bytes available: 5878784
flashfs[0]: flashfs fsck took 9 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:13:7f:e2:34:db
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx"...#########################################################################################################################################################################
File "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Bronze
Re: Cisco 1200 series upgrade failure
I might have an answer for you... or I might be COMPLETELY WRONG
If it isn't just a "failed" upgrade, as in you've tried the upgrade again and it still is happening.... I was reading something about older APs not have a Manufacturing-installed certificate (MIC) and these AP's generating a Self-signed Certificate (SSC).
The error you have is referring to SSC so I'm writing this as if you have not had to previously do this step for your other conversions.
I believe a couple of things needs to happen for SSC AP's.
1) Must enable controller to accept self-signed certificated.
Security > AAA > AP Polices > Accept Self Signed Certificate > Apply
2) Add AP to Authorization List in Security > AAA > AP Polices > Add AP To Authrorization List
Enter MAC Address of the AP
Certificate type = SSC
SHA1 Key Hash can be obtained from the controller by issueing this command:
"debug pm pki enable"
Look for the line: sshpmGetIssuerHandles: SSC Key Hash is XXXXXXXXXXXXXXXXXXXXXXXXXX
I believe you use the XXXXXXXXXXXXXXXXXXXXX as the SHA1 Key Hash.
3) If required, you may also need to add the AP MAC Address in the Mac-Filter: Security > AAA > MAC Filtering > New >
Hopefully its either a reload of the software or this SSC thing that fixes the problem....
Bronze
I did a little more researching and it looks like the LWAPP conversion tool is supposed to provide a CSV file with the SHA1 Key HASH for each Access Point... so maybe I am wrong about the key hash I mentioned in the previous statement. However, maybe that key hash is a return of the debug for when the AP tries to join the controller (and therefor is the right one....)
If you've already done the SSC steps, then I think resetting the AP to default and trying to reload the image is the best step...
222
