CISCO 1200 SERIES
Can anyone recommend a good omnidirectional antenna to use with the Cisco Aironet 1200 Series AP?
Re: CISCO 1200 SERIES
I take it this is for the 802.11b radio as the 802.11a radio has fixed antenna
Any of them on this list will work fine it really depends how much gain you require
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a0080092285.html
dear sir
in the dynamic configuration tool, there is no option for 802.11B radio for 1200 series. please confirm whether B is supported for 1200 and whether PoE is supported for 1200
kalyan
okay it was a premature question
i will answer my own question
AIR-AP1230B will support 802.11b
thanks
405
