Cisco 1200 with EAP-TLS
I am currently using a Cisco 1200 AP with windows IAS 2003 for the wireless solution. I have also implemented client and server certicate for both the client and the IAS server. The problem here is that I am able to get connected to the wireless AP and the IAS server logs a successful authentication but I am getting an invalid IP 169.254.177.45. I have tested using peap/chapv2 but also getting the same problem.
Pls help! Thanks.
Rgds,
Kelvin
1 REPLY
Re: Cisco 1200 with EAP-TLS
Looks like you have not configured the DHCP server for the clients connecting to the AP. The clients can either be configured with a static IP address or must be configured to receive IP from a DHCP server. Check if the DHCP server is configured to provide IP for the clients. This should solve the problem.
113
