04-14-2007 04:49 AM - edited 07-03-2021 01:55 PM
Hi all,
I have a cisco 1231 AP that has 2 SSIDs/VLANS on it.
I am trying to test and even with my laptop with wireless card 2 feet away from the AP, it never trys to associate it.
1 vlan is PSK
Other vlan is Radius WPA
I have been debuging radius and dont see ANYTHING. No attemps no failures. It's like the AP doesn't even know I'm there and or it's ignoring me.
I have verified all interfaces are open.
Any and all ideas to help troubleshoot this would be helpful!
04-14-2007 05:58 AM
Make sure the SSIDs are exactly the same (including capitalization and leading / trailing spaces)
Otherwise, post your (sanitized) AP config.
Scott
04-14-2007 06:32 AM
Scott,
Thanks for the help.
SSIDs are exactly the same as in my client.
I can't even see the SSIDs in my 'scan networks' in my client with the AP 6 inches away.
How can I braodcast my SSIDs just to test?
Vlan 64 = management
Vlan 80 = employee
vlan 160 = guest
Sanitized config attached...
04-14-2007 04:11 PM
Hi Sean,
To add a note to Scott's good info;
In order to enable guest mode (Broadcast SSID) on an SSID, type this command on the AP in global configuration mode:
Ap
Ap
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a008009483e.shtml
Hope this helps!
Rob
