Cisco 1231 not associating client PCs
swoodyard
Hi all,
I have a cisco 1231 AP that has 2 SSIDs/VLANS on it.
I am trying to test and even with my laptop with wireless card 2 feet away from the AP, it never trys to associate it.
1 vlan is PSK
Other vlan is Radius WPA
I have been debuging radius and dont see ANYTHING. No attemps no failures. It's like the AP doesn't even know I'm there and or it's ignoring me.
I have verified all interfaces are open.
Any and all ideas to help troubleshoot this would be helpful!
scottmac
Level 10
Level 10
Make sure the SSIDs are exactly the same (including capitalization and leading / trailing spaces)
Otherwise, post your (sanitized) AP config.
Scott
Scott,
Thanks for the help.
SSIDs are exactly the same as in my client.
I can't even see the SSIDs in my 'scan networks' in my client with the AP 6 inches away.
How can I braodcast my SSIDs just to test?
Vlan 64 = management
Vlan 80 = employee
vlan 160 = guest
Sanitized config attached...
Rob Huffman
Hi Sean,
To add a note to Scott's good info;
In order to enable guest mode (Broadcast SSID) on an SSID, type this command on the AP in global configuration mode:
Ap#dot11 ssid ssid-string
Ap#guest-mode
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a008009483e.shtml
Hope this helps!
Rob
