So far, I've been having a great deal of difficulty putting on the mounting brackets for Cisco 1240 AG access points. Has anyone else had similar problems?
Also, I've ordered the mounting bracket upgrade kit. If anyone else has also, have you found it easier to mount the access points to the bracket?
Finally, are there any other mounting brackets available for the 1240s?
