Community Member
Cisco 1242G-E-K9 Not Seeing other 1242's or 1231 on network
I have a problem where clients cannot roam between Cisco 1231g-e-k9 and recently installed \cisco 1242g-e-k9 access points..  On looking at the CDP option on the 1231 and 1242 access points they are all aware of each other.  However if I use the Network View option I see a different picture.  All the 1231 access points can see each other but not see the 1242's.  Network View on the1242 shows all the 1231's but none of the 1242's.  The 1231 are running ver. 12.3(8)JEB and the 1242's are running ver. 12.4(21a)JA1.
Does anyone have any idea as to what the problem may be.
Many Thanks,
Colin
Everyone's tags (3)
Hall of Fame Super Blue
I have never used network view but you need to consider one major thing:  The 1231 has one radio (802.11b) and the 1242 has TWO radios (802.11a and 802.11b) so maybe that's what you are "detecting" is the 802.11a radio.
Can you make sure your configs are identical and code is same. preferably Latest.
Can you share your configs ?
Thanks..Salil
694
