Cisco 1300 Bridge & Antenna????
Does the Cisco 1300 series AP have to have external antennas when used in bridge mode? Even if it is at a short distance of <50ft?
1 ACCEPTED SOLUTION
Gold
Re: Cisco 1300 Bridge & Antenna????
Depends on which 1310 model you have. If you have the 1310 that uses an external antenna then yes you will need antennas even for a distance that short.
1 REPLY
Gold
146
