11-28-2007 06:26 AM - edited 07-03-2021 03:00 PM
First, i want to apologize for my English.
I have a wireless network, which connects areas isolated by the sea.
One of the repeaters have connection problems.
There is a picture that illustrates my problem.
The repeater in red, was installed recently. Because of the distances are added to each output TNC an amplifier of 1 watt.
The problem arises when the bridge that connects to the repeater, it begins to traffic on the network.
The repeater is disconnected, leaving the bridge and repeater offline.
We believe that the problem is caused by the fact that this link is at 12 meters above sea level. And we think that we could solve that problem by adding two amplifiers to the Master AP.
Any suggestion.
12-05-2007 09:04 AM
Please make sure the correct distance you are maintain between the devices and your configuration between bridge and repeater.
12-15-2007 11:15 PM
You did not include the config files for the 1310's, did you set the distsnce prameter for the radio on the root bridge. for longer distances the AP needs to adjust the time out values.
Hope this helps.
Bill
