jxn
Community Member
Cisco 1310
Greetings...
I am trying to setup two Cisco 1310 bridges (AIR-BR1310G-A-K9-R) for connectivity between two buildings.  No external antennas have been setup yet and I am just setting the basic configuration.
One is running c1310-k9w7-mx.123-8.JEA3, the other c1310-k9w7-mx.123-7.JA1…
I have one setup as a root-bridge, the other as a non-root bridge.
However, even after disabling authentication and encryption, both units are still not talking to each other.  Arghhh....
Maybe a second set of eyes can see an issue?  Thanks in advance.
Root Bridge:
no aaa new-model
dot11 ssid GPRM
   authentication open
   infrastructure-ssid
username Cisco password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid GPRM
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 20
power local ofdm 20
power client 20
station-role root bridge
distance 1
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.31 255.255.255.0
no ip route-cache
control-plane
bridge 1 route ip
Non-Root Bridge:
no aaa new-model
dot11 ssid GPRM
   authentication open
   infrastructure-ssid
username Cisco password 7 02250D480809
bridge irb
no ip address
no ip route-cache
ssid GPRM
no power client local
power client 20
power local cck 20
power local ofdm 20
station-role non-root bridge
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 192.168.0.32 255.255.255.0
no ip route-cache
control-plane
bridge 1 route ip
Thanks for any suggestions....
Joe
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Cisco 1310
Good news Joe. :)
Don't forget to mark the correct answers.
Amjad
Rating useful replies is more useful than saying "Thank you"
Re: Cisco 1310
Jxn:
How do you check if they are talking to each other or not?
What is the distance between your bridges?
Are you sure the RF signal is reachable from one to another? are they line-of-sight with each other?
Try enabling the geust mode (guest-mode) for the SSID if this is going to help.
If I were in your shoes, I would use same version on both bridges to eliminate any (known or unknown) compatibility issues.
Amjad
jxn
Community Member
Re: Cisco 1310
Amjad,
The way I check for connectivity is to see if traffic passes across the bridges.  Also, the logs show
"Interface Dot11Radio0, cannot associate: No Response".
The RF signal is reachable from one to another, as they are just sitting on the bench a few feet from one another.  They are both within line of sight of each other using just the built-in antennas.
Will try Guest mode and trying to obtain a copy of the IOS so that I can update both of them to the same version.
Will let you know what happens... thanks!
Joe
Re: Cisco 1310
After a quick peek of your config, I dont see that you configured root and non root in your config. Also, you should put antennas on these to test. Do yu have them setting next to each other. Also, you should get the latest code and the same code on both bridges for starts.
jxn
Community Member
Re: Cisco 1310
Thanks for your input, George.
The "station-role" is specified in each configuration (see above).
They have internal antennas, so I should be able to have them communicate on a test bench - true?
Working on getting the latest/same code...
Thanks!
Joe
Re: Cisco 1310
Joe:
The no response in the logs mean that the non-root bridge did not reply to the root at all.
Try to remove "distance 1" command as well. this 1 means 1 Km. it should not have big effect anyway but remove it if you are not using the bridges with 1+ Km distance.
try to use Dot11radio1 (802.11a) to test bridging if it works or not.
Also, you can try exchange the roles (root, non root) between two devices and check further.
successful assocaition should be seen by the command:
show dot11 associations.
I hope that after you get both bridges on same version they will sucessfully assocaited.
Good luck.
Amjad
jxn
Community Member
Re: Cisco 1310
Greetings...
I upgraded both bridges to the same IOS and voila they started working...
Thanks for everybody's input.
Joe
Re: Cisco 1310
Good news Joe. :)
Amjad
1013
