Cisco 1532 Autonomous AP's P2P Bridge error
Ramkumar P
Can someone help in configuring 1532's autonomous AP's as point to point bridge.
I have configured root and Non root but Root show the radio up but not the Non root bridge it shows reset and protocol down.
TTried removing the changing roles (Root and non root) between AP's but still no luck.
below error in NRoot AP
*Mar  1 01:46:24.651: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response
Nroot radio 0 output
TS1530NROOT#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.1.8.2        YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  reset                 down
Dot11Radio0.8              unassigned      YES unset  reset                 down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.8         unassigned      YES unset  up                    up
GigabitEthernet1           unassigned      YES NVRAM  up                    down
Switch IP 10.1.8.254
native Vlan 8
Root output
TS1530ROOT#sh ip int brief
BVI1                       10.1.8.1        YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.8              unassigned      YES unset  up                    up
Dot11Radio1                unassigned      YES NVRAM  up                    up
Configs attached for your reference.
5 Replies 5
Stephen Rodriguez
The Non-Root will show status reset when it can't establish a connection to the Root.
On your Root, try adding Infrastructure-SSID under the SSID configuration
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Yes, try what Steve suggested & that should work. Here is a sample bridge config though it is not with exact 1532 model, config should be applicable.
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
*** Pls rate all useful responses ****
Hi Rasika,
Thanks. I used the mrncciew.com for the reference and tried with a spare 1532 AP as well, still the same. Suspecting something new in this model AP's since i couldnt find much documents for this model.
Any Clues/Suggestions ?
Cheers
Ram
Hi Steve,
Tried that but no luck.
Cheers
Ram
Ramkumar P
Managed to get them connected, but I cannot get all the VLAN's pass through the P2P bridges. Only the transit VLAN can be reached from site to site.
Transit VLAN IP is configured for all the devices (Switches and AP's).
In Switch port where AP's connected is configured as trunk with native VLAN and allowed all the VLAN traffic on both the ends. Still other VLAN's cannot be pinged from core.
AP's configured for dot11 1 interface for 5Ghz antenna. and sub interfaces/radoi's configured in AP.
Routing >
Attached the topology for your reference. VLAN 1 is shut, Transit VLAN subnet 10.1.8.X/24
Please help me with this, if any other information needed please let me know....
Ram
