09-21-2013 06:07 AM - edited 07-04-2021 12:54 AM
I have just installed a Cisco 1552EU-E outdoor access point with the standard antennas: AIR-ANT2480V-N and AIR-ANT5180V-N. The 5 Ghz signal is great and still strong (-65 dB) even 100 meters away, however the 2.4 Ghz signal is beyond weak - 4 meters from the AP and it is barely visible. The 2.4 Ghz network is enabled from the WLC and everything looks ok settings-wise. The AP is configured in Flexconnect local switching with a virtual WLC.
Has anyone encountered simmilar issues and found a solution or root cause?
Thanks!
09-21-2013 08:03 AM
From the data sheet, the EU is a single band AP
AIR-CAP1552E-x-K9
802.11N Outdoor Mesh Access Point, Dual band Ext. Antenna
AIR-CAP1552EU-x-K9
802.11N Outdoor Mesh Access Point, Single Band Ext. Antenna
09-21-2013 08:14 AM
Scott, these are dual band APs. The U stands for uniband antennas. The 1552e has dual band antennas and the EU uses separate 2.4 and 5Ghz antennas on this model.
I would check the power level on the 2.4 radio. You might try manually setting it to power level 1.
Show also might post the results of
> show ap auto-rf 802.11b
09-21-2013 06:16 PM
I have deployed a second, identical 1552 for the same project and the signal is strong for both 2.4 Ghz and 5 Ghz.
I have conducted a site survey in the vicinity of the 'faulty' 1552, and within 3 meters of the AP the 5 Ghz signal was -39 dB and the 2.4 Ghz signal was -89 dB and flapping. The power level is maxed out (1). I have checked the antenna connections and they are OK. The funny thing is that when I first installed it I quickly tested the connection using my iPhone 5 and a MB Pro, both which connected in the 5 Ghz band and thought everything was OK. However, users with mobile devices without a 5 Ghz radio soon started to complain about poor / non-existent signal.
Do you think I might be dealing with a faulty 2.4 Ghz radio on the 1552?
The result is below of the command is below:
(Cisco Controller) >show ap auto-rf 802.11b xx
Number Of Slots.................................. 2
AP Name..........................................
MAC Address......................................
Slot ID........................................ 0
Radio Type..................................... RADIO_TYPE_80211b/g
Sub-band Type.................................. All
Noise Information
Noise Profile................................ PASSED
Channel 1.................................... -100 dBm
Channel 2.................................... -96 dBm
Channel 3.................................... -93 dBm
Channel 4.................................... -98 dBm
Channel 5.................................... -96 dBm
Channel 6.................................... -97 dBm
Channel 7.................................... -96 dBm
Channel 8.................................... -98 dBm
Channel 9.................................... -88 dBm
Channel 10................................... -89 dBm
Channel 11................................... -90 dBm
Channel 12................................... -91 dBm
Channel 13................................... -94 dBm
--More-- or (q)uit
Interference Information
Interference Profile......................... FAILED
Channel 1.................................... -88 dBm @ 16 % busy
Channel 2.................................... -85 dBm @ 19 % busy
Channel 3.................................... -87 dBm @ 3 % busy
Channel 4.................................... -90 dBm @ 13 % busy
Channel 5.................................... -88 dBm @ 2 % busy
Channel 6.................................... -92 dBm @ 21 % busy
Channel 7.................................... -128 dBm @ 0 % busy
Channel 8.................................... -86 dBm @ 8 % busy
Channel 9.................................... -84 dBm @ 21 % busy
Channel 10................................... -79 dBm @ 2 % busy
Channel 11................................... -83 dBm @ 10 % busy
Channel 12................................... -84 dBm @ 2 % busy
Channel 13................................... -91 dBm @ 4 % busy
Load Information
Load Profile................................. PASSED
Receive Utilization.......................... 0 %
Transmit Utilization......................... 2 %
Channel Utilization.......................... 57 %
Attached Clients............................. 0 clients
Coverage Information
Coverage Profile............................. PASSED
--More-- or (q)uit
Failed Clients............................... 0 clients
Client Signal Strengths
RSSI -100 dbm................................ 0 clients
RSSI -92 dbm................................ 0 clients
RSSI -84 dbm................................ 0 clients
RSSI -76 dbm................................ 0 clients
RSSI -68 dbm................................ 0 clients
RSSI -60 dbm................................ 0 clients
RSSI -52 dbm................................ 0 clients
Client Signal To Noise Ratios
SNR 0 dB.................................. 0 clients
SNR 5 dB.................................. 0 clients
SNR 10 dB.................................. 0 clients
SNR 15 dB.................................. 0 clients
SNR 20 dB.................................. 0 clients
SNR 25 dB.................................. 0 clients
SNR 30 dB.................................. 0 clients
SNR 35 dB.................................. 0 clients
SNR 40 dB.................................. 0 clients
SNR 45 dB.................................. 0 clients
Nearby APs
AP 00:24:14:31:d6:00 slot 0.................. -63 dBm on 1 (192.168.2.100)
AP b4:e9:b0:16:74:e0 slot 0.................. -53 dBm on 11 (192.168.2.100)
--More-- or (q)uit
Radar Information
Channel Assignment Information
Current Channel Average Energy............... unknown
Previous Channel Average Energy.............. unknown
Channel Change Count......................... 0
Last Channel Change Time..................... Sun Sep 22 03:43:30 2013
Recommended Best Channel..................... 1
RF Parameter Recommendations
Power Level.................................. 1
RTS/CTS Threshold............................ 2347
Fragmentation Threshold...................... 2346
Antenna Pattern.............................. 0
Persistent Interference Devices
Class Type Channel DC (%%) RSSI (dBm) Last Update Time
All third party trademarks are the property of their respective owners.
09-21-2013 08:01 PM
My bad... I don't know what I was thinking. Any who... The only other thing I would do is make sure that the antennas are indeed the correct one for the 2.4ghz radio. Do you have another 1552 and is that working or are you also seeing the same issue. Post your:
show advanced 802.11b txpower
09-21-2013 11:51 PM
Hi Scott,
I have indeed deployed a second 1552 and the signal levels are as expected. The antennas are connected in the right ports, I could try swapping out the 2.4 Ghz antennas :-?
Thank you!
The output for the command is below:
(Cisco Controller) >show advanced 802.11b txpower
Leader Automatic Transmit Power Assignment
Transmit Power Assignment Mode................. OFF
Transmit Power Update Interval................. 600 seconds
Transmit Power Threshold....................... -70 dBm
Transmit Power Neighbor Count.................. 3 APs
Min Transmit Power............................. -10 dBm
Max Transmit Power............................. 30 dBm
Transmit Power Update Contribution............. SNI..
Transmit Power Assignment Leader............... Cisco_01:02:c5 (192.168.2.100)
Last Run....................................... 291 seconds ago
TPC Mode....................................... Version 1
TPCv2 Target RSSI.............................. -67 dBm
TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
TPCv2 SOP...................................... -85.0 dBm
TPCv2 Default Client Ant Gain.................. 0.0 dBi
TPCv2 Path Loss Decay Factor................... 3.6
TPCv2 Search Intensity......................... 10 Iterations
AP Name Channel TxPower Allowed Power Levels
--More-- or (q)uit
AIR-CAP1552-BAD *1 1/5 (15 dBm) [15/12/9/6/3/0/0/0]
AIR-CAP1552-GOOD *11 *1/5 (15 dBm) [15/12/9/6/3/0/0/0]
09-22-2013 06:22 AM
I would try swaping the antennas just to test. From the output, the radio is set as 15dbm just like the one that is working fine. If you swap the antennas and you still have issues, then I would open up a TAC case and tell them what you did and what you have seen and they will probably RMA that 1552.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
02-26-2018 07:19 AM
I have the ANT2480V work with the AP 1562E with a very weak signal too.
My ANT5180V working fine with good signal.
I had make the tx power to level one, and i set the extantenna gain to 16, because this antenna ANT2480V is 8dbi.
I connect it to port 3&4 while the 5G antenna at port 1 & 2.
Any idea what i could change or check for the weak signal?
thank you.
