09-08-2006 10:44 AM - edited 07-04-2021 01:02 PM
I just purchased the cisco 2000 wireless lan controller, and i am having troubles connecting to the console. I have tried win2000 SP4, winXP SP2, i am using 9600-8-N-1. All my terminal says is connected, but nothing dislays. Could it be the cable i am using (are there different types of DB9 cables?). I am using a DB9 female (plugged to WLC) to DB9 female (plugged to comp io port) by the way. Could it be the WLC (it's new).
Please help.
09-14-2006 06:18 AM
you should be using Ethernet cable not crossover because the controller is like a switch and aps are like routers. let me see the sh run of the controller let me see what I can get out of there but I am sure that is the layer one issue.
09-14-2006 08:44 AM
you want to use a straight through RS232 cable, and you want to make sure that you have flowcontrol set to none as well.
